Where is the center of a 4L60e ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2010, 11:41 AM
old yukon's Avatar
Where is the centre of gravity (the balanace point) on a 4L60e?
I putting together a pracket to bolt to my trolly jack, and knowing the centre would really help in design when pulling the tranny.
I guess somewhere around here ( red "x"). Right or wrong??
Name:	centre of gravity on the 4L60e bottom.jpg
ID:	51113   Click image for larger version
Name:	centre of gravity on the 4L60e.jpg
Old 12-27-2010, 02:42 PM
sparkydog's Avatar
Spa Mercenary
Last journal entry: Updates July 2012
Slightly forward of your X with the torque converter still on.
Slightly rearward without TC installed.
Old 12-27-2010, 10:31 PM
old yukon's Avatar
Thanks sparkydog!
Yes that makes sense, the TC with additional tranny fluid is fairly heavy.
Old Yukon
Old 12-28-2010, 06:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would suggest a proper trans jack or at least strap that trans to the device you are putting together.
A falling trans will break and crush various human body parts
Old 12-28-2010, 09:52 AM
old yukon's Avatar
Thanks for the good advice Crosley !
I dont have the luxury of a real tranny jack.
Securing the tranny, i was planning to do that, is heavy duty rope OK? or are chains needed?.
Here is the proposed adaption.
Name:	trany jack adaption small.jpg
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
Looking for a 22 1/2 center to center power rack and pinion grobb284 Suspension - Brakes - Steering 5 09-28-2008 07:26 AM
Lifter Bore Center To Center Measurement 345 desoto Engine 1 08-08-2008 12:48 PM
Center-to-Center diamensions of .... AHotRod Suspension - Brakes - Steering 3 05-23-2002 10:18 AM
Center-to-Center diamensions of .... AHotRod Suspension - Brakes - Steering 0 05-19-2002 02:45 PM
