where are common rot spots on 1972 chevelle 2 door coupes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2003, 09:43 AM
i have a 1972 chevelle 2 door coupe and i am wonderin where the common places of body rot are and where common places on the frame rot are. and if i find any what would be agood way to go about in fixing it. if any one has any information for me that would be great. thanks.
Old 12-28-2003, 07:03 PM
302 Z28's Avatar
Frame rot on a Chevelle is usually not a problem unless it is exposed to extreme conditions. Body areas prone to rust are a follows
Rear window lower corners
Lower rear quarters behind rear wheel because of leak from above.
Front window if it has leaked and not repaired properly.
Rear quarters in front of rear wheels.
Vince
Old 12-28-2003, 07:07 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Don't forget , front fenders lower rear corner.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 12-28-2003, 07:09 PM
poncho62's Avatar
Wiki Edits: 5
Also, bottom of front fenders. Floor panels can be a problem due to previously mentioned window leaks.
Old 12-28-2003, 10:05 PM
thanks for the help. i know this will be a good start for me.
Old 12-29-2003, 04:22 AM
Last journal entry: Some pics
Front passenger floor board. MY 71 cutlass has it there. My old 76 ta had it there also. I think it has something to do with the heater core being on that side.
