i would cut from the corner window around the convet top pinch weld and into the trunk seal lip and then using the old skin as a template trim the new one to a rough fit . This will retain 99% of the new panel and leave you with the smallest amount to but weld to avoid warping. so the only part of the old panne you will keep is the few inches arount that top lip where the convertable top sits....hope ive explained that right
