Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - where to cut quarter panel?
Old 09-29-2010, 11:16 AM
Pontiac_Judas Pontiac_Judas is offline
I'd be very careful where you cut here. I know the listing says "coupe/convertible", but I have heard the area around the peak of the convertible (from about the wheel well up) has a very different shaped "bow" then the hardtop. They say you can "make it work", but you could make a flat sheet of cold-rolled steel work with enough effort.
I would definitely head over to performance years pontiac forum and look around because this type of question has come up there before.
Good luck!
