Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Where did this power booster get its vacuum?
Old 08-10-2010, 01:37 AM
K and K's Avatar
K and K K and K is offline
Last journal entry: Original 365
But thats just it, I didnt see any manifold vacuum ports behind the carb or anywhere in the manifold except for just in front of the carb directly under the pcv inlet of the edlebrock carb the previous owner put on. Perhaps this was the orginal port for the brake booster when it had the original Rochester carb but now with the Edelbrock it cant work because the PCV inlet is to low?
The intake manifold appears original but I have not found a place to decipher codes and numbers of this Caddy.
