Where did this power booster get its vacuum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 12:12 AM
K and K's Avatar
Last journal entry: Original 365
On 57' Caddy I just picked up with its original 365 motor, I noticed the intake manifold has only one vacuum port and it has a very old looking plug in it which sits just in front of the carb flange right under the pcv inlet of the edlebrock performer carb the previous owner put on. The original power booster has an ancient looking vacuum hose hanging from it but I can not find a port matching its length.
Old 08-10-2010, 12:18 AM
SSedan64's Avatar
Booster Vac. hose normally goes straight to Manifold port.
Old 08-10-2010, 01:09 AM
K and K,
I just finished working on a 58 caddy brake system.
The vacuum hose goes to the manifold just behind the carb. If you don't have the original manifold you may need to run a longer hose to a manifold vacuum port.
Have Fun
Scholman(retired)
Old 08-10-2010, 01:37 AM
K and K's Avatar
But thats just it, I didnt see any manifold vacuum ports behind the carb or anywhere in the manifold except for just in front of the carb directly under the pcv inlet of the edlebrock carb the previous owner put on. Perhaps this was the orginal port for the brake booster when it had the original Rochester carb but now with the Edelbrock it cant work because the PCV inlet is to low?
The intake manifold appears original but I have not found a place to decipher codes and numbers of this Caddy.
Old 08-10-2010, 07:12 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Pretty much every Rochester carb I've seen has a port on the rear for a brake booster, even if it just had a pipe plug in it. Perhaps they never got around to hooking the booster back up after the carb swap.
Old 08-10-2010, 08:11 AM
K and K,
Any manifold vacuum will work just fine. Find a longer piece of hose and hook it up. Done!
Scholman(retired)
Old 08-13-2010, 08:23 PM
LATECH's Avatar
Maybe you can find a spacer plate for the carb that has a spot in the back for the vacuum fiitng, or go back to a rochester carb and put one in there. The edelbrock doesnt have a plug in the back of the base plate you can put a fitting in????
Old 08-13-2010, 08:30 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
My 1405 Edelbrock has a port in the back where I installed the fitting for my power brakes . You may have to pull the carb to find it . Shouldn't be a big deal .
Old 08-13-2010, 11:36 PM
K and K's Avatar
Thanks guys, I just pulled the carb to rebuild. Its a 1406 and I did find a port in the rear of the carb to use that I couldnt feel. Thanks!
Old 08-14-2010, 02:02 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
You are quite welcome . A 1406 is a 1405 with an electric choke ( I'm told )
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Disc brakes without power booster? KNanthrup Suspension - Brakes - Steering 10 01-10-2008 10:02 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 01:51 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
