Where did you get the bolts for.....?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2007, 01:55 AM
the steering rack on a M2 setup. I'm using the stock crossmember and can't find the right size or length bolt to hold the rack to the Xmember. I went to tractor supply and only found 6" bolts that were not long enough.
Old 11-04-2007, 04:13 AM
302 Z28's Avatar
A local industrial fasteners supply house should have what you need. The franchised outlets will usually not have bolts longer than 6" as you have found out. You could also order them from McMaster Carr.
Vince
Old 11-04-2007, 10:22 AM
do you know the correct size and length I need?
Old 11-04-2007, 11:47 AM
aka Duke of URL
These are special shoulder bolts that also support the rack bushings.
Orig. FORD STD PN 385506-S100
5/8" - 11 X 7 3/4"
Old 11-04-2007, 12:16 PM
awesome thanks!!!
Old 11-05-2007, 11:17 AM
Well, I went to the local Ford stealership with part number in hand, guy behind the counter said that they are no longer supplied by Ford. So, I hit up the local junkyards on the way home and had no success. If anyone has some extra ones let me know if not I'm going to hit up the M2 boards.
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
