Where do I start? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2012, 05:17 AM
Where do I start?
Whats the first thing I do, to start restoring my trk.
Old 10-07-2012, 07:38 AM
delawarebill's Avatar
take it apart and see what u got... they u'll see how deep your pocket needs to be.
Old 10-07-2012, 09:14 AM
boatbob2
1 st thing.........
BEFORE you take it apart,take plenty of photos,so you know where and how all the parts go back together...
Old 10-07-2012, 09:59 AM
Faith - Respect - Trust
begining
Whatever you take apart, tag and bag every item, even items you are going to replace. The "throw away" Items are valuable to keep because they act as a reference guide to what you need when replacing them. Also, to reiterate, many many pictures, best how to guide you can use.
Old 10-07-2012, 10:27 AM
begining
Also, have a clear picture of what you want the finished project to look like and what it is you want it to be (go fast, all original, street rod or whatever). Figure out what your anticipated casts are and leave extra cash for the unforeseen pieces that always crop up on any build.
I am starting work on a project that has a parts cost of excess of 100K. After all is said and done I build an extra 20% for whatever. This way you can manage your project and as seen to many times when people go over budget, the project gets neglected, the person building loses interest and somebody picks up a project at 10 cents on the dollar.
Old 10-07-2012, 11:29 AM
Crosley's Avatar
Wiki Edits: 1659
Year , make , model of the truck ?
Old 10-08-2012, 02:34 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Make very clear records of the fender shims as you take the truck apart. Reference what thickness shim was used where, then bag and tag. Nothing is quite so horrid as seeing fenders and hoods that don't line up at an amateur car show. Use a scratch awl to mark the underside of the hood where the hinges bolt to it so you can put the hood back in the exact same place.
Old 10-08-2012, 05:52 PM
TucsonJay's Avatar
The first major goal is to get the mechanicals all sorted out, and rebuilt.
This may also require work on trucks wiring, exhaust system, radiator, etc.
It needs to start... run... steer... stop and so on.
Next might be replacing any glass, hinges, latches, bad sheet metal, and so on to make the basic body functional.
Don't even worry about starting on the bodywork, paint or interior until it is functional and drivable. The reason is that there is th epotential for damaging the pretty new paint and interior, while you are working around it.
Old 10-08-2012, 07:54 PM
Senior Curmudgeon
Wiki Edits: 326
Words of wisdom.
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
Lots of issues. Not sure where to start (or if I should start...) oldsevenfire Modern Electronic Engines 18 03-24-2012 01:56 PM
At first start my motor runs great (1968 Corvette 327 motor), at first start, to sscardino Hotrodding Basics 5 12-15-2011 04:06 PM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 08:20 PM
