Where do i start with building a hotrod? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2007, 04:35 AM
well I need to know what is the best car and easiest to find that makes the best looking hot rod
if any1 can answer this plz do
Old 04-28-2007, 04:51 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Noone can answer that cuz theres no single answer to it! "Best car" and "easiest to find" describe no single car either. For example, its hard to beat a 34 Ford coupe or a 68 Pontiac Firebird, but neither is easy to find. And if you ask 100 people that question, youll get at least 99 different answers
Old 04-28-2007, 05:01 AM
I was thinking more classic style hot rod like ford model T and stuff like that I live in australia so any car hard for americans to find would be near impossible here
Old 04-28-2007, 10:22 AM
Wiki Edits: 31
can't you get Fiat Topollino's fairly cheap? they make decent hotrods, and quite diffrent from the normal. otherwise, most any fiberglass body such as '32 Fords, '23/'27 T buckets ect... there are suppliers are here in the US that you 'could' have 1 shipped to australia but it's going to cost. but check around there may be a supplier in australia for the fiberglass bodies.
Old 04-28-2007, 06:01 PM
thnx for the tip :p I will source it out
Need help with a stubborn 4.3L V6 that won't start Mad Maggot Engine 14 10-06-2011 11:48 PM
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
small block chevy cold start problem bennett Engine 7 04-09-2006 11:44 PM
Car won't start, need help!!! kdj997 Engine 6 05-28-2005 01:51 PM
Building a Hotrod Shadetree engineer Hotrodders' Lounge 8 08-07-2004 01:57 PM
