Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Where do jack fornt of 31 coupe?
Old 11-24-2012, 08:17 AM
31ROC's Avatar
31ROC 31ROC is offline
Is there a safe/preferable place to jack the front of a '31 coupe with SuperBell front axle? Am I to place jack right under the center of the axle? Once up, put jack stands under axle, or frame?
PS: the center u-bolt assembly which mounts spring to crossmember,has 4 nuts, of which I found 3 loose! (bought this car this summer and now stored where I can go through it)...Is there a torq spec for these nuts? Has a SuperBell axle and Posies super Slide Spring..
Thanks
