Where do jack fornt of 31 coupe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2012, 08:17 AM
31ROC's Avatar
Is there a safe/preferable place to jack the front of a '31 coupe with SuperBell front axle? Am I to place jack right under the center of the axle? Once up, put jack stands under axle, or frame?
PS: the center u-bolt assembly which mounts spring to crossmember,has 4 nuts, of which I found 3 loose! (bought this car this summer and now stored where I can go through it)...Is there a torq spec for these nuts? Has a SuperBell axle and Posies super Slide Spring..
Thanks
Old 11-24-2012, 09:53 AM
Irelands child's Avatar
Though I have an IFS under my '31, I have a wood block made up that goes to the underside of the front cross member. Then, when I put the jacks under it, I then put them under the frame. There is no reason you can't jack using the axle though - that is if you have a low enough jack. Ford used that basic 'I' beam axle from inception through '48 and you just have to believe that most folks used it for a jacking point if they wanted the entire front end off the ground.
This is where I place the stationarys;
Irelands child
Old 11-24-2012, 09:55 AM
31ROC's Avatar
THANKS!
Old 11-24-2012, 06:42 PM
31 coupe
i have a 31model a coupe with a dropped tube axle.i jack the car up using the axle.if im woking under car i place jack stands under axle,if im woking on front axle i place stands under frame
Torin Black Jack 3-Ton Floor Jack and Stands adamsautoadvice Garage - Tools 11 01-21-2011 11:21 AM
Jack says Hi installerjack Introduce Yourself 6 12-25-2007 05:56 PM
What can i do for my 1940 fornt axel oldskid Suspension - Brakes - Steering 3 06-22-2006 10:12 AM
jack seaswirl Interior 2 04-17-2006 08:08 PM
Hi I'm Jack hillbillyjack Introduce Yourself 4 01-22-2006 12:20 PM
