If Auto Custom Carpets doesnt have what you are looking for, then NO ONE will have it, and it would have to be custom made.
http://www.autocustomcarpets.com/ |
Hey, BigMac
I plan on forming my own carpet from under the dash all the way under the seat. etc. It will require some cutting, stitching and gluing, but it'll be way less expensive than buying those custom molded things. The biggest problem, for me, is finding the carpet I want to use. Stuff made for home use is often too heavy and stiff ... stuff made for auto use is usually solid colors only (which I don't want). But I figure when I'm ready I'll find the perfect carpet - just have to find the right supplier. Where did you put your gas tank? Alan 54 Chevy Pickup |
If you want to do your own carpet, there is one particular type of carpet that i would recommend that is moldable. First the one to stay away from, it is called Needle Punch, otherwise known as a bunch of colored fuzz tangled together. Needle Punch carpet is very stretchy, because it has no backing, but I would NEVER use it. Guaranteed it will fuzz up with 5 drives or less. Maximum of 5000 miles and you will have worn a hole in it. Can't stress it enough to NOT use Needle Punch carpet.
The only kind of carpet that is moldable that is a good quality carpet is Porsche Sliver Knit Carpet, and it comes in a pretty wide range of colors. Yes, it is the actual carpet used in some Porsches, so its a bit pricey, but if you want a nice carpet you can mold, this is the way to go. Id have to check, but im pretty sure its around $50 a yard, and it comes 60 inches wide i believe. And it is the softest carpet you will ever feel. We honestly call this carpet "Teddy Bear Carpet" around the shop because its so soft. Well, i think ive talked enough about carpet for now, off to bed. |
Personally, I'm not looking for soft, plush carpeting in my truck ... also, I don't need to be too concerned about "molding" it. I don't know about your 49, BigMac, but I guess it's similar to my 54 -- practically all flat surfaces. Even my firewall has only a very mild "hump" in the center, and I'm planning on being able to work that with some simple seams.
I haven't gone carpet hunting yet, but I'll be doing that in August or September for sure. I'm gonna check with a couple of local car guys and I'm also gonna look at some regular carpet places (for houses) and see if they have any quality lightweight stuff that offers more than solid colors. These are trucks, eh? Trucks can look cool with something less teddy bear-ish, I think. Anyway, when I see it, I'll know it ... and there's only one way to learn when you're a beginner -- if at first you don't succeed ... Alan 54 Chevy Pickup |
I've been looking for flat,unmolded carpeting for my Model A interior. Try American Trim and Upholstery Supply at atrim.com. They sent me samples of three different grades of carpet and their prices seem pretty reasonable. They also have widths to 80" which will help. If I don't find some at the fall car shows, I'll probabl;y order some from here for the winter projects.
ACC, OR FOR MY TRUCK, I USED SOME STUFF I GOT FOR FREE.
If its flat, no you wouldnt need a carpet kit. But you would need some sort of sill plate at the edge of the carpet at the door opening, or sew binding on the carpet edge.
Thats what I thought. I was looking at some carpet from your (KristKustoms) web site and think its going to work fine. The only place that edging might need to be used is in front of the doors going up the firewall and I don't think it has to be done there.
| Recent Interior posts with photos |
