Where does this washer and gasket go? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2013, 09:54 AM
Hi,
I'm rebuilding my first engine. Ford 460 in a 1993 F350.
I don't know where this gasket and washer go. The gray washer is metal and has a "cup" to it. I don't recall seeing them during disassembly.
The cork gasket seems to fit over the back of the crank where the fly wheel goes.
Thanks
ID:	71503   Click image for larger version
Old 02-19-2013, 02:15 PM
vinniekq2's Avatar
if it came out of a kit,give us a hint to the lineage?
Old 02-19-2013, 02:30 PM
It's part of a Fel-Pro engine kit. Looks like it has every gasket needed to assemble an engine. These 2 items were sealed in this kit.
Thanks
Old 02-19-2013, 02:50 PM
33Willys77's Avatar
The gasket looks like a fuel sender gasket.
The Following User Says Thank You to 33Willys77 For This Useful Post:
Infinite Monkeys (02-19-2013)
Old 02-19-2013, 04:14 PM
Good call. The number of holes would go along with that. Strange it would be part of a engine rebuild kit. I haven't looked at the sender, so I can't say for sure.
Thanks
Old 02-19-2013, 09:54 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Its a blinker fill gasket....Where you put your blinker and headlight fluid.....
No, just kidding...
It would appear to be what he said, send unit for fuel tank.
Diesel or gas engine....?
The Following User Says Thank You to dub For This Useful Post:
Infinite Monkeys (02-21-2013)
Old 02-19-2013, 10:37 PM
life is a temporary assignment
I agree..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Old 02-20-2013, 07:47 AM
[QUOTE=dub;1648215]Its a blinker fill gasket....Where you put your blinker and headlight fluid.....
No, just kidding...
The blinker fluid tank does not have a cork gasket. I couldn't find the right gasket for it, appears there is a national shortage of unobtanium and this is what the gasket is made out of. I just ended up using "right stuff" on it.
What do you think the small, gray metal washer is for?
It's a gas, Ford 460.
(PS, that's funny, it was good for a laugh at 6:00 AM. Good way to start the day)
Thanks
Old 02-20-2013, 08:04 AM
The thing is I have never seen an engine gasket kit, a carb rebuild kit, or anything of the sort that didn't have a few odd seals or gaskets. These kits are made for a ton of motors, not just the exact one you have. So they will often have many, many components that don't go to your motor. That of course doesn't mean you ignore it and toss it in the trash but just to keep things in perspective.
The Following User Says Thank You to MARTINSR For This Useful Post:
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 2 08-23-2012 08:46 AM
Oil pan gasket and timing cover gasket, install? 39chevy Engine 2 07-23-2012 01:04 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 04:15 PM
gasket maker for phenolic 4 hole gasket ? truckboy61 Engine 8 07-28-2011 10:44 AM
water based washer solvent for parts washer 62CHEVYC10 Garage - Tools 31 02-03-2007 07:09 AM
