where does the wire go
731 views 3 replies 3 participants last post by  gorilla13
I'm installing a electric fan and the sensor that goes in the rad has 2 wires on it. I know 1 goes to the relay but where does the other 1 go thanks.
#2 ·
Ayuh,.... If it's like the 1s I've installed, that's a Switch, not a sensor, 'n is a pass-through switch,...
So,....
You can wire the power to the switch, then the second wire would go to the fan motor,...
Or,...
You can run the power to the fan, 'n the ground through the switch, 'n the 2nd wire would go to Ground...
