-   -   where the fuel filter and help with missing (http://www.hotrodders.com/forum/where-fuel-filter-help-missing-82957.html)
tsw5013 03-01-2006 07:33 AM
I have a 2003 trailblazer and can't seem to locate the fuel filter. I have begun to experience a miss when you accelerate and am guessing that perhaps this is the problem. If anybody has any other thoughts please share. I recently also began having the CES light come on and the code is p1481. I think that may be tied to the fan however as it sound like it is running on high sometimes (it makes it sound like the truck is in low gear). It is a vortec 6 cylinder. Also I am not the smartest guy in the world when it comes to new cars but I can't seem to find the spark plugs either.
thanks
302 Z28 03-01-2006 07:36 AM
On Chevy trucks and SUV's they normally located the fuel filter along the frame rail under the drivers seat.
Vince
1931 steve 03-01-2006 07:46 AM
Its right next to the fuel tank, just fallow the fuel lines and you will find it.
Steve
tsw5013 03-01-2006 07:50 AM
thanks for the info. again not to seem stupid, but does this thing have hidden spark plugs somewhere?
thanks
1931 steve 03-01-2006 08:15 AM
This is a coil over plug set up, plugs should run down the center of the valve cover, the only thing you will see is 6 identical looking things that go through the valve cover, they will heve a electrical connector on the top, with a hold down bolt. remove these and you will find your plugs.
73oldsman 03-01-2006 01:01 PM
http://www.troublecodes.net/OBD2/Pcodes.shtml#1400 reads "P1481 Fan Secondary Low With High Fan On"
tsw5013 03-01-2006 03:59 PM
thanks for the info. can you put in english what fan secondard low ----- means.
thanks
73oldsman 03-02-2006 12:26 AM
I'd just be guessing. You may want to call the dealership on this one. Sounds to me like the fan is running low speed when hi speed needed, but not sure. Maybe someone else reading this post knows? Anyone, anyone, Ferris?
tsw5013 03-02-2006 08:16 AM
you all have been very helpful and I wanted to ask another question. I post this question seperately before thinking to just add it here. I now have what appears to be a flooding (bogging down) issue. From a stop it does not do it, but when you are traveling and have to pass somebody and punch it it bogs down and sounds like it is flooding itself then takes off. Any advise?
thanks
73oldsman 03-02-2006 09:05 AM
Have you changed the fuel filter yet? Plugs?
tsw5013 03-02-2006 09:23 AM
I changed both last night. Had a bit a trouble with number one plug as they built up all that plastic around it but got it changed. ANy other ideas?
thanks
