Where to get 1965 chevy truck BBC headers?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2008, 09:14 PM
I am asking for a friend, he's getting a big block for his 65 panel truck, and i want to know where I can find a set, I haven't bin able to find them??
Old 03-19-2008, 09:51 PM
Last journal entry: Resizing the rear window
Try Sanderson headers. They seem to make them for just about everything. http://sandersonheaders.com/ Dave
Old 03-19-2008, 10:07 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cam Lobes
I don't have the cab on my 1966 GMC frame yet ... just the engine and trans sitting on the frame with a set of Hedman headers.
I bought them used at a swap meet ... HOPING that I could make them fit ... and I think I lucked out. They seem to fit like a glove, actually.
The part number is stamped into the flange ... and I'm quite sure it is 68111. The application is late 70's pickup wih a 454.
I don't have the inner fenders on yet, and as I said the cab isn't in place yet either ... but I can't see any possible interference areas anywhere.
They clear the crossmember and fit inside the frame rails with room to spare, etc.
The date-stamp on the picture is wrong ... should be January 2007.
edit:
I guess I should mention that the entire font suspension clip (crossmember, control arms, ball joints, spindles, sway bar, steering linkage, calipers ... everything) are from the same late 70's pickup. See my journal for details.
Old 03-19-2008, 11:37 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The correct # for the headers is 69111- 68 to 87
3/4 & 1 ton 396-502.
Rich
Old 02-17-2013, 09:31 AM
1965 truck headers
the that used the headers in the 67 and newer fram the engine sits 4 inches higher than it fits in the 65 frame due to the newer style motor mounts i have a 65 with a 396 bbc in it with the stock mounts and moved it forward to clear fire never did find the right header did use a set of 425 horse cast iron manifolds
Old 02-17-2013, 11:26 AM
68NovaSS's Avatar
Wiki Edits: 9
X2 on the Sanderson's, they have a set, SKU C6-SEC that should fit. I just got T-Bucket headers and they're nice, ceramic coat inside and out, with a limited 5 year warranty.
New owner 58 chevy truck Lee Hester Introduce Yourself 5 10-29-2006 03:45 PM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 06:06 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
