Where to get alternator bracket for no-bolt hole heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2003, 09:42 AM
New Member
Post Where to get alternator bracket for no-bolt hole heads?
I have some some camel-hump type heads with out accessory holes. Where can a get a bracket to mount my alternator? Thanks.
Old 04-01-2003, 12:04 PM
woodz428's Avatar
Troll Hunter
Arrow
Several shops that cater to the rod business have them, you might check out a Rod & Custom or Street Rodder and you'll surely find something to fill your needs in the advertising section (in some magazines that seems like what it mostly is).
Old 04-01-2003, 12:09 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I make all my own brackets.
Old 04-01-2003, 12:13 PM
EBlack36's Avatar
Rebuilt Excitment
Post
Thy Alan Grove Components the below link should take you there. I am using his brackets on my 327 with the double hump heads with no accessory holes.
http://www.alangrovecomponents.com/
Old 04-01-2003, 01:21 PM
New Member
Post
Autozone and Advanced Auto both sell a bracket that bolts in at the #1 exhaust flange. Then you use an adjustable bracket from the front of your intake to the top of the alternator. Brackets are reasonably priced and are even chrome.
[ April 01, 2003: Message edited by: 48liner ]</p>
Old 04-01-2003, 05:43 PM
Post
I am using Alan Grove brackets on my 327 Vette motor. Hve PS, Alternator on the left (drivers side) and AC compressor on the left. Every thing bolted up nicely using the intake and water pump bolts. There are others such as March but you are going to put out more bucks.
Trees
Old 04-01-2003, 05:44 PM
Post
Woops, AC is on the right.
Trees
Old 04-03-2003, 11:41 PM
Post
I;m gald i read this. I just got a pair of camel humps from the machine shop and the tech. pointed this problem out to me. I had never even thought about it.
