Where to get high flow fittings...?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 01:58 PM
I was wondering where you guys are getting these fittings, I was going to get the Harbor Freight ones but read they restrict airflow bigtime. Any advice...? thanks
Old 11-28-2005, 03:03 PM
Sharpe spray guns have them.
Old 11-28-2005, 03:31 PM
BarryK's Avatar
Almost any major paint jobber will have them.
The best ones made are "Prevost" and the best money you will spend is the quick release that goes on the hose.
I have not seen a major paint store that did not have a Prevost supply.
I'm not sure I spelled the name right but that is how you say it.
Old 11-28-2005, 04:10 PM
Beleive or not I got mine at walmart, lol, yes high flows, they are campbell houseld , they were back by the air tools, I have them on all my air tools, they seem ok, no problems
Old 11-28-2005, 05:13 PM
Last journal entry: final pics of first engine swap
Ditto, I heard about them being under $6, so I went and got 2 of them, should have gotten a few more, but a seriously low budget has stopped me, they're the 3/8 with the 1/4 npt fittings, huge difference, came with 3 male connectors, 2 of the npt's male and 1 female. I'll try and grab 2 more next week.
The brand name ones I saw were around $15. Just trying to help those on a low budget too
Old 11-28-2005, 05:28 PM
Thanks alot guys, I try Wally World tomorrow
Old 11-29-2005, 04:34 AM
adtkart@aol.com
I got some at Lowes a while back. They were the same fillings that we had at the shop. It seems that they were about $7 for one male and one female. I thought about leaving them alone and seeing if they multiply. LOL
Aaron
Old 11-29-2005, 06:11 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Are the ones at Wal-Mart high flow? Or are they
just the next size up, from 1/4" to 1/2"?
The larger 1/2" ones I looked at would have to be
adapted down to fit the standard 1/4" hose fitting.
They are made for 1/2" hoses, (which is probably
better to use anyway)
Old 11-29-2005, 09:03 AM
X711
I got mine at sears, Lowes did not have them in my area. When you purchase them look at the size of the inner hole. Sears calls them industrial connectors.
They look physically big. !
Thanks... X
Old 11-29-2005, 03:08 PM
Heres what they came in. No adapter needed and they say 3/8 T on them. Also compatible with the HF Amflo CP7-RET, I just test fitted them now to make sure they fit and they do. Wich means they should also fit CH PA1011, Tru-Flate 12-602 and Milton 1809.
Its actually same diameter all the way through. Should be hi flo's.
Old 11-29-2005, 03:21 PM
Oh yeah, I accidentally bought an I/M connector. Found out its only for industrial fittings. On the back of the CH PA3001 box it shows it can be either:
I/M=Undustrial
T=Automotive
A=Aro
U=Universal
Also says interchangable with
Milton "H" style
Amflo Type "G"
Camel Type "G"
Truflate "T" style
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 06:06 PM
too high of oil pressure? Jared Engine 2 09-03-2003 11:18 PM
SBC High Volume Oil Pump 360Camaro Engine 4 08-19-2003 12:43 AM
