Where to get Phillips bit for 60's GM door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2011, 12:07 PM
cyclopsblown34's Avatar
Colorsanding painter
Or is there a tool that was made just for this purpose? Right now, I use the big phillips bit from my impact driver set with a ratchet wrench but was hoping there's something more efficient.
Thanks, Chip.
Old 04-19-2011, 02:19 PM
It's a number 4 phillips as I remember. I have one and it works just fine. I use a butterfly impact, I have found that is the best tool for such things.
Old 04-19-2011, 02:33 PM
Thanks Brian, I'll get one and give it a try. the way I've been doing it just seems so durn inefficient.
Old 04-19-2011, 06:31 PM
where to get phillips bit for 60's gm door hinges
I had to remove my doors on my 67 chevelle. Brian is right #4 phillips socket. I had to use my 3/8 impact and some heat. Hope I helped.
Old 04-26-2011, 09:29 PM
Phillips bit for GM doors
Try any Snap-on or MAC tool vendor. This is a common tool item they carry. I'll bet many local Auto Parts dealers can get one for you in a day or so.
Normbc9
Door hinges scottyd Body - Exterior 1 03-25-2008 06:44 PM
good 60's era 4 door project? legionlleh Hotrodders' Lounge 6 03-05-2007 09:57 AM
door hinges cjskustoms Body - Exterior 1 09-02-2006 04:22 PM
Door Hinges 1935 Ford Steve Body - Exterior 1 05-17-2006 01:04 PM
Help with door hinges ets1945 Body - Exterior 3 11-28-2003 06:50 PM
