where to get a quality 383 stroker kit ? (Long) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2006, 06:01 PM
Mustangsaly's Avatar
where is a good place to get or look at a quality balanced 383 stroker kit ? I would like to look at some different kits & prices (I would like to look at a internal & external balanced kit with full floating pistons and 5.7 rods) this is for a 350 2bolt main 1 piece rear main block. I would like to look at cast & forged kits, I don't need a forged kit for this Suburban build, but the stroker might end up going from the Suburban to a S10 in the future (with a few changes like head & cam change B4 going into the S10) the S10 will see a hard street time & some 1/4mi time ( S10 will be tubed and ladder bar rear suspension with a ford 9" ect.) or is a forged stroker kit in a 2bolt main 1 piece rear main block krazy ? or should I build one motor at a time ? you know instead of trying to over build one motor for 2 uses. I have another 1971 std. bore rebuildable 350 4bolt 2 piece rear main block that I can build later for the S10. plus I have a std. bore rebuildable 1981 right hand dip stick 2 bolt 2 piece rear main block to.
Mustangsaly
Old 07-18-2006, 06:13 PM
cabowabo's Avatar
big Q
here a few
www.enginekits.com they good and prices are killer and nice folks too
www.cnc-motorsport.com
Pontiac Fiero Owner swapping in a 350, maybe 383 sbc with a v8 archie kit Fiero Performance Engine 2 02-24-2009 04:30 AM
383 stroker deiseling when I try to shut er down tdhixon Engine 6 09-27-2007 12:31 AM
383 Stroker Beowulf Engine 2 07-14-2006 07:08 AM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 11:05 AM
I need your feedback Specs for my new 383 stroker ozzt Engine 12 01-11-2006 10:12 AM
