Where to get tail light lense red plastic
I have a friend who needs to make some custom tail light lenses but we can't find a supplier for SAE approved color in small quantities. Does anyone out there know of a mail order source?
Try one of these, maybe a phone call to one of the companies will give your friend what they need.
http://www.installer.com/lights/ledlights.html http://www.taillightking.com/index.htm http://www.customclassic.com/product.../ledlights.htm Dutch |
Thanks Dutch but they seem to sell lights and we need sheet stock. I thought for sure someone sold that stuff. My local plastics shop will sell us a 4'x8' sheet but that is a little overkill!
Did you see the Dec 03 issue of Street Rodder? There is a very good article on how to make your own custom lenses in any shape you want. Process not much different that the front end you made on your Willys. They used a 2 part clear urethane and mixed ruby-red dye in it to get the desired color.
I suppose another option would be to scour your pic-a-part until you could find a lens that you could modify. BJB Enterprises sells the moulding and urethane compounds. www.bjbenterprises.com Ross |
Willys, try this place US Plastics I am almost positive that you can buy sheets of any type plastic from them. The company that I work for used to buy plastic sheets from them for various projects. That was a couple of years ago. You may want to call them just to see.
Later, WEIMER |
I'll check with them and get back to you. How much material are we talking about? 2' x 2' or 2' x 4' or what? How critical is it that the red lense color is SAE approved? Is that for insurance reasons because I doubt if a cop would know SAE from XYZ. I made a set for my brothers 54 and he hasn't been hassled about them.
He want to make tail light lenses and a blacked out dash insert so I assume 2'x4' would be more like it. I said SAE approved 'cause he did. I don't even know if there is such a standard but it does eliminate the usual fluorescent red that is most common.
This place used to sell scraps (some were 2'x2') a buck a pound.
http://www.tincna.com/ainp/division/...html/home.html or try http://www.americanacrylics.com "custom colors available" Last edited by fat50; 01-06-2004 at 12:14 PM. |
This is how I made the bubble top in the picture below. ![]() Quote:
If your still looking for the red plastic I know a place down by my moms' Called South Bay Plastics. If you need transparent red I can call and see what they have. Let me know
Regards Mark |
Most states require a reflector inside the light, or built in the lens.I know someone sells it , I've had customers that furnished there own, but never bothered to find out where they got it. I'll check around.
Troy |
Still looking so would appreciate your help guys. My friend will put the lens over the stock reflector and cut some diffraction grooves in the back of the lens so it should work as good as a stock light.
