Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Where is the passenger compartment wiring harness?
Old 07-05-2012, 11:59 AM
mike69 mike69 is offline
OK, so I checked out the plug near the fuse box and it seams ok. I'm getting connection across the plug. When I checked the orange and white wires coming out of the plug and heading toward the ribbon wire I found that the orange is always dead whether the door is open or not, but the white wire has .04V through it with the door open and 12V through it with the door close. Not sure what this means, since I thought the orange was supposed to be the hot wire. Any thoughts?
I also checked the actual socket and found the same thing. The orange wire is always dead, and the white shows .04V with the door open and 12V with the door shut.
Mike
