relays
I would put one relay for the fans on the inner fender and direct wire the fuel pump with a heavier wire.
Re: relays
I have 2 fan relays 1 fuel pump relay and several other relays that will be doing different things. All tolled about 5 to 6 relays. So you can see that putting these all over the fender's and on the firewall will look kind of messy with all of the wiring. That's why I'm looking for an enclosure to put then all into.
Go to a salvage yard and purchase the box only from them. You can usually search any yard at will,remove the box,you can keep the bus bars inside if they are there and remove what you do not want. That way you know you have a stout piece that will handle the underhood and environment since it was designed for that. Then when you find a place to install it in your Vette you can run all the wiring and route the relays the way you want.
Yep..That's what I leaning towards.. Can't belive that even a company like Painless doesn't make anything like that. Well..maybe I should start building and selling a few.. Any more idea's??????? |
Roll your own
I would think that a fellow could get some Lexan and build a box that would meet your needs..as far as building something like that for sale I do not think anyone would have a clue as to how big, how many relays or any of that, that may be needed by any individual car builder....
OMT Home bro!!
When I wired my key-less remote system I mounted everything to a panel then put the panel into a Tupperware type container. I drilled holes in the back to mount the case to the front of the trunk and one hole to allow all the wires to exit. I like to use balk head connectors so I can remove the whole assembly without cutting wires.
It worked good for 10 years. I am now redoing it because the old system died. I am doing it the same way. One advantage to wiring it into a box is that you can conserve wires. You only need to bring one Feed one Ground and one Ignition Feed. I used those screw terminal blocks to share the power and grounds to all the relays. You can place the fuses inside the box too. Now the only other wires going in and out are the low volt switch wires and the high output power wires. You are talking about exposing the box so I would find a good style box or make one. Look at tackle boxes, tool boxes, or go to target and look for anything that is a box - lunch box? Could be cool. Or make a louvered panel to cover a boring box. Last edited by evltwin; 02-18-2005 at 06:58 AM. |
Yep...That's excactly what I want to do... Consolidate it all together... Now..Guess what I found yesterday..... Somebodies Got there tinking cap on . Check this out.. Now I know I'm not crazy.. http://www.dedenbear.com/mrc1txt.htm |
The relay center looks cool.
Some things I like better about the homemade system is the price and the closed box. The relays are still open on that product. Left in the engine compartment they can be difficult to keep show clean. If you are planning on driving and showing the car. I checked Ebay and there are some relay centers for sale there. Someone else here had suggested looking at using a production car set up. It all depends on how you want your engine compartment to look. Many hot rodders like to hide/creatively run their wires. Some like to see the gritty look of modules and wires exposed. Your body is fiberglass if you don't care about being original you could cut a hole into your firewall/wheel tub/radiator support and cast a box into the hole. Then use the piece you cut as the door to the box. Run all the wires in a channel cast with the box and all the wires would be hidden. That is alot of work and time but its an option. Might have to design your engine compartment. |
http://www.radioshack.com/search.asp...41&image1.y=31
When I put the relays in for the driving lights on my truck I used a "Project Box" from Radio Shack. Lay out your relays in an organized manner and measure the size. RS has a number of different sized boxes so you should be able to get one that will work or use two or three. They are very cheap and work great. I routed all of the wires up through the bottom with factory loom and painted the box body color. It looks factory and nobody even notices it hanging on the left front inner fender. The removable lid will polish up nicely or you can paint it also. Mark Last edited by astroracer; 02-18-2005 at 10:17 AM. |
relays
I have painstakingly removed every relay out of my car. The starter solenoid is the only one left. I can't imagine anyone wanting to put more in a car.
