Where to put power steering pump?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2012, 10:27 PM
chevyrestore's Avatar
1980 454 motor in a 1959 chevy pickup- I am converting it to power steering and running V belts not the serpentine. Alternator is on top passenger side right in front of the valve cover, a/c is up top on the drive side in front of the other valve cover, running a mech fuel pump and have the long water pump.
Anyone know of a specific power steering pump bracket I can use with this setup and where it would mount? Thanks
Old 07-20-2012, 01:24 AM
327NUT's Avatar
I would think most speed equip. shops would have the necessary bracket (s) or a trip to the boneyard might work. Sometimes you just have to make your own.
Old 07-20-2012, 04:32 AM
STUPID is as STUPID does...
I am using Tuff Stuff brackets. Bolted right up using an '86 Chevy 1 ton hydroboost power steering pump and it is hanging on the front of the mock up block.
I just need to get a nice looking pulley.
Mark
Old 07-20-2012, 05:43 AM
That is the same mounting location as my stock PS pump, but it looks like the Tuff Stuff bracket is set up for serpentine (there is no adjuster?).
I would look at stock GM PS brackets from the mid to late 70's to mount it low on the driver's side, unless they interfere with the frame. Alan Grove also makes some replacement brackets that look they would work to mount the PS low on the driver's side.
Bruce
Old 07-20-2012, 06:39 AM
The adjusting slot is at the bottom bolt. Tuff stuff bracket # 6503B Short water pump/V-belt.
Summit has them on sale right now so check them out. You'll need a different number for a long pump.
Mark
Old 07-20-2012, 07:32 PM
Cape Cod Bob's Avatar
Speedway and summit have bkts that look good. I just used a stock bkt off an 87. I did modify it to pull it back closer to the block and in doing so had to use oledr pump to clear the block.
belt, power steering, pump, rack and pinion
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
has anyone put power steering on p15 p15 guy Suspension - Brakes - Steering 1 09-24-2007 11:26 AM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 03:02 PM
power steering pump baumholder19 Suspension - Brakes - Steering 2 04-09-2006 10:53 AM
power steering pump help billyr Suspension - Brakes - Steering 1 02-06-2004 09:20 PM
