Where to put trans cooler? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2013, 09:01 PM
On my 1952 GMC restromod I do not have room behind the front grille for a trans cooler. So I picked up a cooler with it's own fan but I still do not where to put it. Does anybody have any experience with such a problem? Will the fan make up for being out of the air current like up under the bed? Will I need a thermostat to control the fan? Thanks.
Old 01-10-2013, 08:09 AM
life is a temporary assignment
I run a trans cooler like this one..In all my cars.. Mounted under the car or truck right inside the frame.. Ran these for years with no problems..
If you have one with a fan that makes it even better.. You can run it anywheres under your truck you want...Just make sure you have it where the fan can push air though it.. Keep it away from the exhaust as much as you can.. You should be OK..
Old 01-10-2013, 08:50 AM
sedanbob's Avatar
Since your cooler has a fan, it should be good just about anywhere you put it. Most of the coolers with fans also have a thermostat to control it. I think the thermostat is a good idea - you don't need to keep the trannie cold. The stacked plate style have more cooling capacity than the finned tube style.
Old 01-13-2013, 03:48 PM
I have one of those single pass round 24 inch coolers that is pickied up new at a swap meet for ten bucks and haven't enstalled it yet. Have you ever used one of those. Looks like the double pass one someone posted here. Just got my project completed and thoght i'd get that done before warm weather gets here. Maybe i should use a dilfferent tpye.
Old 01-13-2013, 06:07 PM
sedanbob's Avatar
I haven't used one of those, but lots of guys have. Any is better than none. Maybe you can search for the specs on one of those to see how much they compare. None of them are particularly expensive - especially when compared with a transmission re-built!
Old 01-13-2013, 08:15 PM
I have used them before, With no problems at all... I think I had them on about ten cars I had..
If your going to use one.. Get the one with both fittings on one end... That way you don't have to have the extra hose it takes to run to the back side.. Much easier..
Old 01-13-2013, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A tranny cooler thermostat is nice but not absolutely necessary.
The main thing is that there be unobstructed airflow in and out. The closer it's placed to a surface, the less potential airflow it'll have. Keep it away from the exhaust and you'll be fine.
using a trans cooler for a gas cooler? biohazard_81c10 Hotrodding Basics 2 09-05-2011 02:09 PM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
trans cooler tomco550 Transmission - Rearend 1 10-06-2006 03:44 PM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Trans cooler 302 Z28 Transmission - Rearend 2 07-30-2003 10:33 AM
