where to put the wire ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 06:41 PM
I want to re-route the wiring harness that usually goes under the door sill plate. I'd like to run it on or along the tranny hump, but then I'd have to cut and splice it to make it longer. It's been suggested that I run it under the floor in or along the frame...what is your opinion of this ???
Old 05-18-2008, 06:51 PM
poncho62's Avatar
Wiki Edits: 5
A lot of the manufactures ran it in a flatish plastic sleeve and just ran it under the carpet in the middle of the floor.......It will get wet there in the winter however.........the hump seems like a good place. ...I wouldn't run it outside of the body.....The elements will get to it and corrode the wires.
Old 05-21-2008, 11:33 AM
now I'm confused ! Iam wiring in the origianl ('48) AMP meter, where should it go ? I'm using a battery terminal (junction block ) on the firewall.... shouldn't the amp meter be 'spliced' in between the battery terminal and the battery ? If it was on the Alternator side, how can it show a discharge ?
Old 05-21-2008, 01:00 PM
re
Amp gauge goes between the battery and the 'load'. It does not show current that moves around in the car, only current going to and from the battery.
Generally this means you run a big cable to the starter, and then a smaller heavy wire to the fuse box or terminal that everything in the car gets it's power from. The amp gauge goes in this circuit.
Old 05-21-2008, 01:50 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
An Amp guage is designed to be used with a generator.....alternators use volt meters.
Old 05-21-2008, 02:43 PM
re
not reeeeeeaally
plenty of cars out there that came with alternators and amp gauges. my old 73 satellite wagon for instance.
volt gauges are a whole lot cheaper to design in, they can be wired in anywhere, but I don't think they tell you as much as a good amp gauge. My cars I can tell if the brake lights work, radiator fan comes on, blinker is blinking.....
Old 05-21-2008, 05:02 PM
Lost in the 60's
Wiki Edits: 4
Originally Posted by kgus
not reeeeeeaally
Your right ...all the newer stuff that I see is using a volt guage...and all of the aftermarket wireing kits that I have used are usually set up for a volt guage.
Old 05-21-2008, 05:08 PM
poncho62's Avatar
Wiki Edits: 5
I think the car companies started using the voltmeter as a safety item.........An ammeter being wired in series requires that a large load comes into the interior of the car.....more chance of a fire.
Old 05-21-2008, 05:20 PM
40 grey's Avatar
Dusty mayhem
wire harness routing
I routed the wire harness for the rear section of my 40 chevy through the a-pillar out from under dash and fuse block. It then continues back through roof line and come out c-pillar into trunk of car. Then fastened to bottom of package tray with adel clamps and wire loom and distibuted to various loads. Works good, almost completely invisible. I added a few "spare" wires just in case of future use, breakage, etc.. Also loomed anywhere it lays against metal for possible chafing. Just something to think about.
Old 05-21-2008, 05:35 PM
thanks guys, for your thoughts, come to think of it this '48 did have the wires going up 'A'post .
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Harris 20 gauge welding wire Hot Rod Mike Body - Exterior 14 09-07-2011 10:22 AM
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 08:29 PM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 09:01 AM
need help with a 12 v to 6 v reducer oldguy829 Electrical 32 08-21-2006 05:02 PM
