I prefer to run my filter between the pump and carb, incase anything in the pump breaks loose.
What carb are you running? If a Qjet, you can use the one behind the fuel inlet. They work fine, especially the long ones. |
put 1 before the pump, and 1 after the pump.. I hate changing the internal pump filters.
I ALWAYS run two filters. One on the frame rail before the mechanical fuel pump and one between the pump and the carburetor. The one on the frame rail catches anything before it gets to the pump. The other one is just INSURANCE
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
lol, thats what I was basically looking for was the insurance portion of it.
NOW, from the hard line to the filter is a pretty good angle and is putting a kink in the line.... best way around that? Run longer hose or can I get an angled fuel line? I don't want to run a long hose b/c of A. Clearance and B. I don't want the fuel filter flopping around. |
yupp.. that and most stock fuel pumps have filter screens.. when they clog up, I hate changing them. run a simple in line filter b4 it, and it will never get debris in it. one between carb and fuel pump, just for precaution
Ok, no problem. I'll go get another filter tonight. Easy sneezy....
But that is a straight shot from pump to carb. Run that inline no problem. How do I overcome the angle from the hard line to the pump
Ok, I just put one filter before and one filter after....
Technically electrical question though. I think the wire gauge I have for the electric choke is one guage size bigger than the wire guage coming from the choke.... Is this a problem? Its about 8 inches from the choke and then another 3 feet or so of the thicker guage. I was planning on hooking the wire to the starter.... sound good? |
| fuel injected engine needs fuel filter | autonut | Engine | 3 | 04-13-2008 08:54 AM |
| fuel filter before or after fuel pump? | pi71 | Engine | 6 | 09-10-2007 12:41 PM |
| Revamping Fuel System | topdogger | Engine | 6 | 12-29-2006 12:13 AM |
| Fuel Filter Question | NovaSS350 | Engine | 5 | 04-25-2005 05:18 AM |
| fuel filter | astrops | Engine | 4 | 05-13-2004 11:11 PM |
