Good luck finding those parts for the 8.2 in a junk yard. A posi in the 8.2 was very rare. All Chevy 10 bolt rear ends from '65 to '70 are the 8.2. Chevelles used the 8.2 from '64 to '72.
Well he is on a budget so instead of hunting for all the parts we may get a
1995 and up Explorer rear end (8.8) that already has 31 spline axles, and 3:73 gears, with disc brakes for a few hundred bucks. All that would be required fitment wise is to cut and relocate the spring perches and have the axles re drilled for a chevy pattern wheel. |
I use car-part.com as that is the online wrecking yard parts locator..
Sam
Just did that dance,although my issue is slightly differential than yours
The 69 impala I got came with an open 2.73. I wanted to stay open in the heavy ol beast. I tightened everything up on my 67 charger so it all got to the pavement and spent 99% of my time changing parts. Finding parts for 8.2 in yards,all the luck friend, and when you go from a 2 series gear set to a 3 series dont forget to order the .3" spacer for behind your ring. I'm hoping those little diffs can take some pounding
8.2" parts are getting very hard to find. 10-Bolt Info here>> http://www.oldsmobility.com/10bolt-tech.htm |
| 8.2 pontiac rear end. | studlyrocker1234 | Transmission - Rearend | 2 | 04-24-2009 06:14 PM |
| 32 PB rear end parts needed | wicasa | Transmission - Rearend | 1 | 04-16-2009 08:23 PM |
| Rear end swap required & I'm cunfussed | datsun dale | Transmission - Rearend | 8 | 12-17-2008 09:03 AM |
| 10 bolt rear end question 8.2 or 8.5 ?? | nheron | Transmission - Rearend | 6 | 03-02-2008 08:16 PM |
| Rear end swap problems | datsun dale | Transmission - Rearend | 1 | 12-17-2002 10:50 PM |
