Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Where to Start.....
Old 02-26-2003, 12:59 PM
pasadenahotrod pasadenahotrod is offline
Post
Here's how I see it if you can devote the extra bay to the car during good weather:
1. NOW...Take detailed photos of every aspect of the body, inside and out, as it is currently assembled (presumably from the factory). Mark and file these in a nice album for reference.
2. NOW...After the photo session get the shop vac and go over the interior parts of the car thoroughly, don't forget the trunk.
3. NOW...Remove the headliner the easy way. Use a boxcutter or sharp scissors and carefully cut around the installed parts (visors, mirror, dome light & switch, etc.). Then sweep and vacuum up all the nastiness.
4. NOW...If your seats are as nasty as the headliner, strip them the same way. Bag all the trash, vacuum again and again.
4. NOTICE... I did not ask you to remove anything from the car except the trash, mouse nests, droppings, etc. That's because if you do you'll never remember how to reassemble it all even though you have the book of photos you carefully made to eliminate that possibility.
5. The car is now covered with a tarp or old sheet. You have your fine album of photos titled "MY HOTROD PROJECT".
6. NOW, go to the website of Motorbooks International and look through their titles concerning your 1935 Ford. You might want to buy "The V8 Affair", "The Early Ford V8 As Henry Built It", "The Restorer's Guide to the 35-36 Fords", the reprint of the Owner's Manual, the reprint of the accessories brochure, the reprint of the Ford Factory Service Bulletins, and several other books perhaps including some about building hotrods from the Tex Smith Collection. This will cost you close to $300 I would guess at today's prices. When the UPS man comes, sit back and enjoy your reading, get to know your car, sit in the garage and read to her, prevent yourself from diving in without a life preserver!
7. NOW...decide which end of your car is up to be worked first.
You'll need a place to store the body while you finish the chassis. Is there room in your wagon, mower bay?? Build a nice heavy-duty body dolly and store the other sheet metal inside it while you build your chassis. It'll probably fit crossways at the back of bay 2 with a tarp over it.
