Where is transmission filter located on 2001 Mitsubishi eclipse auto? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2008, 06:55 PM
I went to the part store, and it is a screw on filter, and I just cannot seem to find it on the tranny! Any help would be greatly appreciated. thanks!
Old 09-23-2008, 07:18 PM
Wiki Edits: 31
check Autozone's repair center.
Old 09-23-2008, 07:30 PM
It only tells where the fuel filter is, I already looked on there. Nothing about tranny
Old 09-23-2008, 07:46 PM
Wiki Edits: 31
click on the repair guides at the top next to the drop down for your vehicle.. the instructions are there, I checked.
Old 09-24-2008, 04:26 PM
Well, I found out that the filter is a screw on, on top of the tranny, and I looked, and there is a spot where it looks like its cast for one, but there is no filter, hole there. I am stumped. any input?
Old 09-24-2008, 04:48 PM
SSedan64's Avatar
I looked on Rockauto's site and they show a spinon filter and a filter that is inside the trans pan. Maybe you have the internal filter type trans.
Old 09-24-2008, 05:11 PM
I think that your right, but I called oriellys, and they only have listed a "spin on"
Old 09-24-2008, 06:14 PM
Wiki Edits: 31
call the mitsu dealership, get the parts dept.. if there is 2 options but 1 of them was an early design and not used long, a regular parts store might not have the less popular style..
2001 mitsubishi Eclipse A-Frame/Lower control arm bent PLEASE HELP!! jordan2011 Suspension - Brakes - Steering 6 08-15-2008 05:17 AM
2001 Eclipse problems jordan2011 Engine 2 08-08-2008 09:30 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Manual or Auto transmission? '54-Hunter Hotrodders' Lounge 20 01-12-2003 08:07 AM
