Where is the vacuum on my 350 SB Chevy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2005, 06:49 PM
frankenvette's Avatar
Go ahead kid squeeze the wheez
I have been searching for a vacuum line on my 350 SB Chevy engine and can't find it. Where should the vacuum line be coming from? I know it goes to my carburetor, but where does it come from? Little help please!
Old 04-09-2005, 07:24 PM
NorthStar's Avatar
They dont go to the carb they come from it generally.
Two different types of vacuum that are used for different things.
Ported vacuum source is just above throttle blade and increases as throttle blade is opened. Used for distributor.
Manifold vacuum source is anywhere below the throttle blades is high at idle and will decrease when throttle blade is opened. Used for power brakes, actuators on heater controls, and other things like cruise control, headlight doors, etc.
Old 04-09-2005, 08:20 PM
Thanks Greg, makes sense! I put a new carb on today and had to block the vacuum. Never really though about it before. This would mean my advance is purely mechanical, correct?
Old 04-09-2005, 09:53 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
yes
The vacuum advance is for fuel economy and does not restrict performance.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 01:42 PM
Chevy 350 vacuum tree color code Jag Daddy Engine 1 03-29-2003 02:21 AM
