whining in reverse? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2006, 08:14 AM
whining in reverse?
I have a 88 caprice with a 700r4 and a 350sbc. I heard a small clunk when i was in drive and when i went to put it in reverse it does not engage just whines when i tap the throttle.
Old 10-31-2006, 08:23 AM
whining in reverse
Have you also lost 2nd and 4th?If you have ,your sun gear shell is the culprit.
Old 10-31-2006, 09:56 AM
I'm not sure it happened right when i got home and went to back up. i need to get to work tonight so i'll know then. I called a tranny shop and they said it would be ok to drive it just dont try to use reverse. so maybe i will have time to trouble shoot later.
Old 10-31-2006, 10:05 AM
scrot's Avatar
That's because it will be a bigger repair bill when you bring it to them.
Old 10-31-2006, 11:40 AM
whining in reverse
I don't know where you are in Wisconson,but I have dealt with Darrel at Darrel's transmissions in Waukesha,he's a good guy and will treat you fair.
Old 11-01-2006, 07:41 AM
I am in horicon. But if the price is right whats a little drive. the shop is also suspecting the sun shell. so far i have a quote of $450.00 just to pull it and inspect it. does that sound like a fair price?
Old 11-01-2006, 08:44 AM
whining in reverse?
I would ask for an overall estimate for repair,[rebuild].I don't like the deal where they say they charge this much just to find out.I would get an estimate and do some shopping around.
Old 11-01-2006, 08:52 AM
Thanks Briscoe. I kind of thought the same thing that was a pretty high number just to pull it out and look at it to find a problem for sure. I have been calling around, and found a new tranny for 900.00 so if all else fails I will do the dirty deed myself and just put in a new tranny.
IN the meantime gonna call around to some local shops and see what I can find out.
I appreciate all the help and input, might be asking for some more info soon
Will let ya know how it all turns out.
Old 11-01-2006, 10:05 AM
whining in reverse?
The sun gear shell problem is pretty common.What I'm saying is when you go back with new trans you don't want to go thru this again.
The updated shell or the beast shell would be a good choice.I tig weld the splines to the shell in 4 places,for 10 years now,no failures! Good luck.
Old 11-06-2006, 07:13 AM
Hey briscoe I got my tranny in. They rebuilt mine and put the beast in it. Along with a corvette servo and what ever else they did to give it good hard shifts. Thanks again for all your help.
Old 11-06-2006, 07:29 AM
whining in reverse?
I'm glad it worked out well tinman!
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 05:07 AM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
350tranny. no reverse. Sonkey Transmission - Rearend 3 02-11-2004 11:31 PM
