Whining sound from distributer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 01:32 PM
I have a high pitched whining sound coming from what seems to be the distributer or at least at the back of the engine. Found no vaccum leaks or anything. It just started making the noise and always does whetehr I'm in park, drive, anything. The only time that it quiets is for a second right when I rev it up. Any ideas?
Old 07-04-2005, 10:00 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
whining
Sounds like bad distributor bearings. Buy a new MSD. It comes with ball bearings instead of the sleeve type.
Old 07-04-2005, 11:10 AM
I've heard this noise before too.Once when I used the lightest sprigs in a recurve kit.Put the medium back in and it went away.
Old 07-04-2005, 11:58 AM
GoneNova/406's Avatar
you didn't say what dist. you have but try rebuilding or swapping yours.maybe you have a buddy who has the same type dist you can swap with him to see if thats it.
Old 07-04-2005, 04:11 PM
It's a stock GM HEI with the medium springs in it, but it didn't start till long after I swapped the springs. Yeah, I have another stock HEI lying in the garage that came out of my old motor which worked fine, so I'll throw it in there, but I'm probably going to rebuild it since it's already out of the car and I need higher voltage anyways.
What determines engine sound? Nightfire Hotrodding Basics 10 12-16-2004 05:45 PM
funny engine sound brad11957 Engine 5 05-13-2004 09:59 PM
ticking sound from distributer Echofive Engine 2 04-05-2004 12:26 AM
I've got a ? about distributer placement. bowtieorbust Engine 1 02-29-2004 08:35 PM
