Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Whining sound like a super charged? Cause?
Old 12-26-2005, 04:52 PM
IanRiordan IanRiordan is offline
If it's pre efi, and a t350 would inicate that, try the distributor. Dry points or a stuck weight (points or hei) touching inside will cause it. At least if you unbutton the convertor you'll get closer.
