Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Whining sound like a super charged? Cause?
Old 12-27-2005, 12:28 AM
97Z28's Avatar
97Z28 97Z28 is offline
NTI Grad.
depends where the sound is coming from. start the engine and let it idle till the noise comes in, then go through and check to see where the sound is coming from with a mechanics stethiscope.... or... whatever you have... you should be able to tell where its coming from. and if it only happens when your driving, i'd check the tranny, and also check to see if the rear end has enough fluid in it...
