my uneducated guess, a vacuum line somewhere is leaking. fwiw.
The carb base gasket will squeel real loud when it gets a leak.
If it's pre efi, and a t350 would inicate that, try the distributor. Dry points or a stuck weight (points or hei) touching inside will cause it. At least if you unbutton the convertor you'll get closer.
depends where the sound is coming from. start the engine and let it idle till the noise comes in, then go through and check to see where the sound is coming from with a mechanics stethiscope.... or... whatever you have... you should be able to tell where its coming from. and if it only happens when your driving, i'd check the tranny, and also check to see if the rear end has enough fluid in it...
| Dynomax Super Hemi Turbo sound clips? | JohnTN | Engine | 0 | 09-21-2005 07:08 PM |
| Knocking sound from the rear | Arcuden | Transmission - Rearend | 1 | 08-14-2005 03:05 AM |
| Whining sound from distributer? | 1quiknova | Engine | 4 | 07-04-2005 04:11 PM |
| What determines engine sound? | Nightfire | Hotrodding Basics | 10 | 12-16-2004 05:45 PM |
| GM 3800 super charged | Joe S | Engine | 18 | 05-07-2002 04:50 AM |
