Whipple aux injectors VS marine intake build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 03:48 PM
I was wondering if anyone has tried using the Whipple aux injectors without the Whippletronics to overcome the limitations of the Vortec spider injectors? Waht about using a piggyback management unit (emanage?) or secondary controller (http://www.splitsec.com/products/aic1prod.htm)?
Old 12-22-2007, 11:41 PM
I am using teh marine intake, if you use those extra 2 injectors with teh stock L31 vortec 350 intake, you are GOING to get horrible cylinder to cylinder distribution problkems. That intake is designed to flow AIR ONLY. Get a marine intake, The swap is easy.
peace
Hog
Old 12-23-2007, 09:59 AM
Vortech 4.3's Avatar
jack of all trades
convert a carb manifold to injection. thats what i did.
Old 12-25-2007, 09:57 AM
Yes thatw orks very well also. It pretty much matter how good the persons fabrication skills are.
I like the MArime intakes because they look stock and are designed my GM, but the converted carb intakes probably make more power.
This is my most favourite marine intake manifold. The Scorpion Tunnel ram with 90 mm t-body.
the lower plenum and fuel rails
http://www.mercruiserparts.com/Show_...AND+FUEL+RAILS
the upper plenum and t-body
http://www.mercruiserparts.com/Show_...FLAME+ARRESTOR
This is the cross ram marine intake that I am using.
http://www.sfatek.com/images/efi.jpg
peace
Hog
Marine 383 build mtnrat Engine 25 03-31-2014 06:47 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
Anyone build 351C 2V heads w/460 intake valve? Aussie XAXB Engine 2 11-20-2005 07:56 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
