Whistle from TH350c - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2009, 06:09 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
Whistle from TH350c
I installed a fresh TH350c and there is a noticable whistle coming from it when in gear. It is more noticable when in reverse (a constant whistle when stopped or moving).
The whistle is quieter and not as constant when in a forward gear. I think it gets louder when up to speed but I have loud exhaust (Dynomax bullets muffeling the 468ci) and meaty tires so it is hard to pinpoint. I just notice a sound while driving that wasn't there before I swapped trannys.
The shop is going to take care of it (plus the labor and I installed the trans). I'm just curious if any of you have heard of this or maybe there's a tranny expert here.
The shop owner who built the trans says he seems to remember reading something about a 350 whisle but it was years ago and he has never actually had it happen to a trans he built.
Old 05-15-2009, 06:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It could have some kind of blockage in the filter. I have seen this happen and cause a whistle. It could also be a vacum leak. Cole
Old 05-15-2009, 07:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 70bird
I installed a fresh TH350c and *snip* I have loud exhaust (Dynomax bullets muffeling the 468ci)
I'm curious as to what was done to your tranny to make it hold up to a BBC?
Old 05-15-2009, 07:36 PM
70bird's Avatar
A vacuum leak at the trans???? Is there another source of vacuum other than at the modulator???
The TCI clutch drum was the main upgrade. A larger bearing was also used in the torque converter. The shop owner said as long as it is built right and with the correct parts it will hold up...and he built it.
Old 05-15-2009, 07:58 PM
SSedan64's Avatar
That's the only vacuum line @ modulator. May be a bad bearing inside trans causing noise.
Old 05-15-2009, 08:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
OK, thanks.
Rear Gear Ratio Question - SBC with TH350C Houston54 Transmission - Rearend 7 03-19-2009 09:35 PM
TH350C Questions baspinall Transmission - Rearend 3 09-01-2006 09:56 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 09:03 AM
Converter whine or whistle sound???? Slant3 Transmission - Rearend 8 04-19-2005 02:10 PM
whistle goes wooooo!! peteypablo General Rodding Tech 2 06-19-2003 01:25 AM
