whistling noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2004, 11:19 AM
lovoiboy's Avatar
Angry whistling noise
i have an 86 chevy camaro 305 4bbl. i recently took my passengers side head off to get a bolt drilled out of it. after i had put it back on i threw a new edelbrock intake manifold on it too. now the engine is making a small whining/whistling noise. it takes about ten minutes before it starts. also after about fifteen to twenty minutes a louder whistling noise is coming from what seems to be the tranny. if i push in the clutch it goes away when it first starts. but after it has been doing it for a while it whistles no matter what. if any one can help i would appreciate it. thanks!!!
Old 08-31-2004, 11:37 AM
Wrencher's Avatar
I'd say you have a vac leak and a noisy throwout bearing!
Old 08-31-2004, 12:55 PM
DoubleVision's Avatar
usually if you can push in the clutch and the noise goes away, it`s either the throw out bearing or worn input shaft bearing.
Old 08-31-2004, 06:50 PM
GoneNova/406's Avatar
i agree with the vaccum leak.how did you seal the end rails on the engine?
Old 09-01-2004, 08:13 AM
lovoiboy's Avatar
where and what are the end rails on my engine??? maybe thats the prob!
Old 09-01-2004, 08:15 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
had the same problem once, sounded HORRIBLE. Turns out I had a piece of zip tie stuck under the carb lol.
K
