White camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 06:44 AM
White camshaft
I have a 350 and there is a knock in the engine. I was informed that i have a cam that is white and i was asking how this happens. The motor is only 20,000 miles on it.
Old 11-07-2008, 07:01 AM
I suspect that someone told you you have a "Wiped" camshaft.
That means a lobe, or lobes have worn excessively due to excessive valve spring tension, or insufficient lubrication, or both
JA.
Old 11-07-2008, 07:15 PM
you are correct thank you
Old 11-08-2008, 07:14 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Or wiped due to improper break in or break in oil without enough ZDDP additive.
Old 11-09-2008, 05:54 AM
the reason i ask i have a 350 and it was replaced about 20,000 miles ago. last week it started to knock in the valves. The only thing i did to the motor was over tighten the rockers studs when the head was pulled off. I was told to tighten one was and it was wrong. I have been driving it for 4 months. Now it knocks when it is drive and i try to increase my speed. The friend said the motor is still under the time to replace. Or do i replace the camshaft my self and go on. Thanks Joe
Dark panels on a white car SVOHIO Body - Exterior 6 06-07-2007 04:54 AM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
White Primer VWFan Body - Exterior 27 10-13-2004 12:39 PM
do you want a white background? Jon Hotrodders' Lounge 13 06-13-2003 09:42 PM
