Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - White smoke
Thread: White smoke
Old 08-09-2003, 12:45 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
Most likely the problem is with the valve guides... On startup it will bleed down some oil from the loose valve guides and also at an extended idle time (developes higher vac) if its under power when it smokes then it could either be the rings or possibly a turbo seal on the exhaust side...? More likely its the valve guides...
