Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - White smoke
Thread: White smoke
Old 08-09-2003, 02:13 PM
Chevy Guy Chevy Guy is offline
New Member
Thanks for the help. It only smokes when you first start it (pretty bad) and then if you blip the accelerator after it has been idling. Not much of anything as you are driving or really getting on it after it has warmed up. The engine has been tested for compression and it has had a leak down. Both were good-no problems. I'm leaning towards water in the cylinders, but I would think that it should smoke all the time. Hadn't considered the valves because I figured the smoke would be blue (Oil buring). Any other thoughts?
