white smoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2003, 11:09 PM
Post white smoke
I have not run this engine for about 3 years and it is puffing white smoke out of the left side exhaust. I just let it run about 10 or 15 minutes and then shut it off. I have a few guesses but would like some otherideas...thanks Brad
Old 01-29-2003, 11:18 PM
Post
It sounds like steam is coming out your exhaust it could just be condensation evaporating from your motor and exhuast I would run the engine for a while longer and see if it doesnt clear up. Is the motor running smooth no misses?
Old 01-29-2003, 11:25 PM
Post
Yea, the engine started up on the first crank, and is running like a champ. I thought that it was just burning some junk out of the system, but then got kind of worried and shut it off.
Old 01-29-2003, 11:36 PM
Post
I blew a head gasket in my mustang and when I fired it the first time after fixing it there was a ton of white smoke coming out my right tail pipe it took about 30 mins for it to completely burn off. If it is running good I dont think you have a blown head gasket. Check your oil for any milky residue and check your radiator for oil. Check all your plugs to make sure nothing is a miss. Steam is the only thing I know of that could be white.
Old 01-29-2003, 11:44 PM
Post
Thanks, I did pull the plugs and did not notice anything wrong, and I did check the oil and found it was the same as before I started it. I did not check the radiator for oil. How long before that would show up?
I just looked under the cap and did not see any oil floating, is that what you mean?
[ January 30, 2003: Message edited by: bnesbitt45 ]
[ January 30, 2003: Message edited by: bnesbitt45 ]</p>
