White smoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2006, 11:10 AM
White smoke
I've got white smoke while idling or driving, makes me think head gaskets blown. Dipstick shows clean oil , no milky look, no increase in fluid level. Water in radiator looks clean. Oil filler cap has grayish color gunk on bottom.
Any other possibilities but gasket or cracked head?
What tests will narrow it down, and any easy fix? Thanks
Old 02-04-2006, 11:12 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
We have had the head gasket go out on two cars in two months. I feel your pain.
On one its not getting into the oil but its making it to the combustion chamber. The other we have milk shake
what kind of car?
Old 02-04-2006, 11:43 AM
Jmark's Avatar
What kind of car and what trans? Pure white smoke is usually caused by a bad vacuum modulator sucking trans fluid into the intake. More info would help.
Mark
Old 02-04-2006, 03:52 PM
vfast racer
try a compression test..also is the antifrezze bubbling in the over flow tank? or fill up while idling? the car is fully warmed when this happens right?
Old 02-04-2006, 06:04 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If possible (Carbbed) look into the manifold, Is it reddish in color? If so you have a modulator gone south..Does the smoke smell sickly sweet?
Pull the line from the Carb going down to the Transmission, and plug the carb side..Run the car about a half an hour (in the driveway) Does the smoke dissipate? If so replace the modulator.
Also, If not that, Does the Radiator require constant topping off? Run hot or misfire at any Engine RPM? If so this would indicate a head gasket/Cracked Head/block or bad intake manifold gaskets. Blowing as much smoke as you say, It should be constantly low..and run bad.
Pull the plugs, are any Wet, with water? Crank it while watching the plug holes, do any spray water?
Do a pressure test on the radiator, does it hold pressure..
Try those and let us know
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-04-2006, 06:06 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I'm fairly sure that you can have a shop do a test for the presence of combustion gases in the coolant.
Old 02-05-2006, 07:07 AM
Garbonzo Bojangles's Avatar
Youre confusion is not logical
I car does a little of this, and like yours the oil and coolant are fine. I wasn't able to diagnose the problem in time for winter, but I believe my problem is gas. Either from the cam overlap, clean heads, or junk additives, there is no mistaking that it smells like gas. I still have to retorque my new heads, so maybe there is some cylinder leakage, but I've heard the Fel-Pro blue gaskets are supposed to be okay without one. Maybe it's the crap AC Delco plugs I run, or a bad coil? Can't say for sure, but I can say when I took my phenolic spacer off the driving smoke decreased, probably due to better atomization in the Vic Jr.
And for the people who say white smoke is not gas, run a carb with no primary jets and tell me what color the smoke is...
Old 02-06-2006, 12:16 AM
Any chance it's just condensation in the exhaust system evaporating?
Old 02-15-2006, 07:45 PM
Hows your car doing? I killed the motor in my car 2 days ago. We had some real cold weather and I think my thermostat stuck shut. The motor overheated while I was cleaning the ice off my window.
All the water from my motor is in the oil
Anyway I have another car almost ready to drive so its not too bad.
White smoke, water in oil... Blazin72 Engine 6 09-25-2005 05:02 PM
Bewildered at the white smoke? HotRodMan Engine 5 09-08-2004 10:32 PM
White smoke after intake swap Gmachine Engine 5 02-28-2004 08:03 PM
Blowing white smoke esears Engine 18 10-01-2003 12:32 PM
white smoke and engine dropping revs when put into gear andybird Engine 2 06-24-2003 01:01 AM
