White smoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2006, 10:02 PM
White smoke
I have a 67 camaro which I just purchased, the first night that I drove it I blew the right head gasket. I know, stupid right? Yet the gauge did not show the car to be hot and nothing seemed wrong until I turned it off and herd the radiator bubbling. After restarting the car it started smoking out of the right exhaust pipe, I changed the both head gaskets and im steal getting a light amount of white smoke out of the right side. I did not have the heads checked due to available funds and they are aluminum. also i found out when I pulled the heads that the engine is a 400 sb bored 60 over which is not good. Is there any products that can be used to fix the problem that really works, until I can afford to build a 355, and still be able to drive the car?
Old 08-16-2006, 10:07 PM
Johnny's 67,
I use KW Block Seal. Follow the direction "to the letter" and it will fix the problem and not plug everything else up too.
Scholman
Bewildered at the white smoke? HotRodMan Engine 5 09-08-2004 09:32 PM
White smoke after intake swap Gmachine Engine 5 02-28-2004 07:03 PM
Blowing white smoke esears Engine 18 10-01-2003 11:32 AM
White smoke Chevy Guy Engine 6 08-10-2003 04:17 AM
white smoke and engine dropping revs when put into gear andybird Engine 2 06-24-2003 12:01 AM
