White smoke after intake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2004, 01:18 AM
Gmachine's Avatar
New Member
Red face White smoke after intake swap
Whats going on . Got a little issue with white smoke. I just swapped intakes on my camaro. After install of all componets back with new manifold, I let the car sit for 24 hours. I cranked it set timming then all of a sudden I had white smoke comming out of the breather on the valve cover. The car did not do this prior with the old manifold, nor have i had this problem before, The motor is the original block just rebuilt, 327. Please lend me some advise if you can thank you. also The manifold I replaced is brand new edelbrock performer rpm out of the box , ne gaskets evrything.
Old 02-28-2004, 09:20 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Sounds like you might have a water seepage around the intake gasket. Is there a milky substance around the breather or just inside the valve cover? Also check the oil for moisture. Good Luck
Troy__________________
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-28-2004, 10:08 AM
Gmachine,
Is the PCV hooked back up?
Scholman
Old 02-28-2004, 05:45 PM
Gmachine's Avatar
New Member
Thanks for responding, I did check pcv and oil for moisture. Found milky white all over, I will pull manifold and check gasket, also what is the best way to flush the engine now that it has been exsposed to water. Thanks rory.
Old 02-28-2004, 07:59 PM
troy-curt's Avatar
Just refill and run until temp comes up for a few minutes,
Then change oil and filter again, it should be alright.
Troy
Old 02-28-2004, 08:03 PM
Gmachine's Avatar
New Member
Thanks bud, will do , Might just go ahead and change oil and filter a few times to make sure. Thank you...........
