white smoke... burnin oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2009, 08:23 PM
ok... need some help here. I got white smoke and funny smells coming from my exhaust. also, if you take off the valve cover, there is black carbonation-lookin stuff over where the first cylinder is. and in the first, it is also leakin oil into where the spark plug hole, and when the car idles there is a clicking sound coming from the first cylinder.
whats the problem here? bad valves?
edit: forgot to mention - when I took the valve cover off, there was a piece of debris - broken off something, just sitting there. Also, one of the bolts holding the head down is broken off... so, its pretty much not there. I just discovered this, and the car seemed to run... kinda. any connection?
Old 09-29-2009, 08:39 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Time to roll out the toolbox and begin disassembly.
Old 09-29-2009, 08:42 PM
ericnova72's Avatar
More for Less Racer
White smoke as an indicator means water is being burned. That and the fact you have found a broken head bolt would usually mean a cracked head or cylinder wall, or a blown head gasket. Looks like you will be working on it.
Old 09-30-2009, 03:10 PM
oh great... thanks yall
Help me figure out where my Oil is going :( Malibu73 Engine 22 02-20-2006 11:21 PM
White smoke crash Engine 8 02-15-2006 06:45 PM
White smoke, water in oil... Blazin72 Engine 6 09-25-2005 04:02 PM
Bewildered at the white smoke? HotRodMan Engine 5 09-08-2004 09:32 PM
white smoke and engine dropping revs when put into gear andybird Engine 2 06-24-2003 12:01 AM
