Condensation in the exhaust system........an engine produces lots of water
Ontario Rodders |
What about the coolant loss? Just a coincidence?
I remeber when i bought my truck with the 5.3 it warned me of low coolant a day later. Then never again. Weird... Should i do any tests on it? Cooling system pressure test? |
a pressure test wouldn't hurt anything. how much white smoke? is it oil smelling, fuel smelling, or coolant smelling? how do the plugs look?
the basic diagnostics can tell you a lot. |
My 5.3L did the same thing when i bought it with173k on it it now has 266k and runs like a top
It wasn't a lot of smoke, just cloudy i guess you could say. |
Head gaskets.
The intake has no coolant passage. A small amount of coolant is seeping into the combustion chamber after the engine is shut off, upon retsart later it puffs the coolant out, then clears up after a few seconds. You can pull the plugs and look at them , you will probably see the coolant residue (color) on them.
Fact is stranger than Fiction |
Most likely not. It is an obvious miniscule breach in the head gasket, and takes a while for the coolant to seep into a cylinder, you wouldnt see anything that miniscule on a gauge for the cooling system.
Your best bet is to read the plugs, also if it misses on start up, even just a little it may set a pending code or a one trip code for a missfire on the affected cylinder. Bottom line though is coolant dissapearing slowly and no visible external leak, accompanied by puff on start up, very indicative of a head gasket leak.
Ontario Rodders |
It pays to shop. I cant answer the question, you have to.
Is it worth it to you to put head gaskets in it? 175,000 miles, 10 years old... 4900 bucks, tax , title , transfer of tags, repairs, all just to drive ??? ![]() How do the brakes look? Are the ball joints OK? Tires? AC? Look at the big picture. Sounds like impulse buying to me.
| White smoke | crash | Engine | 8 | 02-15-2006 06:45 PM |
| smoke at startup | davidbull | Engine | 10 | 12-27-2004 10:06 PM |
| Lotsa smoke at startup. (Stock Chevy 350 with Q-Jet carb) | Terje | Engine | 8 | 07-17-2004 06:57 PM |
| White smoke | Chevy Guy | Engine | 6 | 08-10-2003 04:17 AM |
| white smoke | bnesbitt45 | Engine | 4 | 01-29-2003 10:44 PM |
