who balances torque converters? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 04:24 PM
i want to balance my t. c. , because i want to add a plug on the outer edge,so that i can drain the fluid completely. anyone in the l.a. area do this?
Old 02-18-2005, 06:13 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I'm sure they do
Check the yellow pages.
Old 02-18-2005, 06:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
We used to drill and tap converters as they drained while still in the car.
Never had a "shaker" afterwards.... We used an 1/8th inch pipe thread plug
Old 03-18-2005, 10:02 PM
you have any pics?
Old 03-19-2005, 01:12 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Most places that rebuild trannies will drill & tap the converter to drain and clean. The difference that you drill out vs. the weight of the plug is so minimal that one offsets the other.
Kevin
Old 03-22-2005, 08:24 PM
What if you put 2 holes 180* apart? They'd balance each other, & maybe it'd drain faster. Might be hard to account for all the drilling chips, though.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Torque Converters schuffm Transmission - Rearend 2 10-30-2004 01:21 PM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
