Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Who builds the best 200r4 tranny
Old 01-16-2013, 02:37 PM
dwwl dwwl is offline
So you have any idea what gave out on the tranny ? That is why i say, the 200 4r has to be built better than just stock for your big block. It will need a better forward shaft and other internal parts, more clutches, with better clutches than just stock components. Remember, your tranny will only be as good as your weakest component. Don't tell yourself that you can get buy with something less, because there will be a time when you WILL get on it, and that big block tq will take care of it. Maybe not the first time, but it will happen. You will only get what you pay for. If you have any knowledge of trannies, you could rebuild your own like I did. But you have to study about the 200 4r. Having the TV system set up right and having higher presure is half the problem. I still believe You need to talk to a good tranny builder. Good luck
